I have tried to use the "Publish i-model" that is in the the new Bentley Map (standalone)
All I get is a message in the status line saying: "Publish: 0 succeeded, 1 faild, 0 up-to-date, 0 already publish"
I have attached the XFM designfile.
What am I doing wrong ?
TIA
Erik
Erik,
Would you be able to perform an i-model publishing test on a similar design file that does not contain any feature instances with special/accented characters in the feature class and business property names? I'm wondering if those characters as seen in the following feature instance are causing the publishing process some grief. If not, please let us know and we will continue our investigation.
Jeff Bielefeld [Bentley]
Jeff,
Yep!
Publishing an I-model from a XFM file which have no danish characters in features and properties works okay.
So again whose æ,ø and å makes problems. Maybe Bentley should open a special test center in Denmark :-)
Erik Wirring
...thank you Erik for the confirmation and we are continuing to investigate this further. A special test center in Denmark, now that has some interesting possibilities. :)
