"NOT LIKE" operator
Is there any way to effect a "NOT LIKE" or "NOT IN" operator when defining thematic labeling or symbology?
Parents Reply
  • Rob;
    The labeling tools was set up to just do fairly simple labeling. If you want to make a graphical comparison based upon the value in each feature instance,you could use the Symbology option for the paticular layer ( feature) in the map manager. Set the symbology type to Thematic, in the first form. You then can specify the feature symbology based upon property values. This also can be saved as a .theme file and reused in another map model.
    HTH
    Jerry
