This is probably something I am just doing wrong, but I am having trouble loading my 3D features (buildings) into our Oracle Server (11g).
I have created me GSA project and created a couple of features, now I want to load these into Oracle. I used the 'dgn2sdo' utility to create the Oracle scripts to upload the data, but this seems to have failed.
In my DGN2SDO logfile I found these lines:
Commencing translationERROR: Error encountered while translating instances = (Exception of type 'System.NotSupportedException' was thrown.).System.NotSupportedException: Exception of type 'System.NotSupportedException' was thrown. at Bentley.EngineeringContent.Storage.Xfm.ECXfmSupport.ManufactureInstanceToStore(opaquePointer* feature, Char* pFacilityUuid, IOgcSpatialReference targetSpatialReference, ECObjectToXfmWorkingStorage workingStorage, Boolean populateOnlySimpleProperties) at Bentley.EngineeringContent.Storage.Xfm.ECXfmScanDgnInstanceCursor.Read() at Bentley.Geospatial.Dgn2Sdo.Dgn2SdoTranslator.Translate(IECInstanceCursor instanceCursor)ERROR: Error encountered while translating instances = (An unsupported Microstation element type of 94 has been encountered, and cannot be converted to an OGC geometry type.).System.ApplicationException: An unsupported Microstation element type of 94 has been encountered, and cannot be converted to an OGC geometry type. at Bentley.EngineeringContent.Storage.Xfm.ECXfmSupport.ManufactureInstanceToStore(opaquePointer* feature, Char* pFacilityUuid, IOgcSpatialReference targetSpatialReference, ECObjectToXfmWorkingStorage workingStorage, Boolean populateOnlySimpleProperties) at Bentley.EngineeringContent.Storage.Xfm.ECXfmScanDgnInstanceCursor.Read() at Bentley.Geospatial.Dgn2Sdo.Dgn2SdoTranslator.Translate(IECInstanceCursor instanceCursor)Total instances read = 2Total instances written = 2Translation completed
And when I check my DAT file the third dimension is missing from each surface of my building.
I am using Bentley Map Enterprise and Oracle 11g (not Oracle Spatial).
So what is the correct process for creating and 3D features in Oracle?
Regards Ian
If you are using dgn2sdo in "dgn" mode then the level you specified probably contains this element. you could just move it to another element, or use the geometry parameter instead.
