Opening GIS data files from MAP running in ProjectWise
has anybody a solution for letting MAP recognize that it ir running in ProjectWise when opening GIS data files from import?
I'm pretty sue it is an issue of settings in a cfg file.
At least there are 2 msgeo.cfg available. Setting the PW variable to various values didn't help.
Thank you
Hubertus
Parents Reply Children
