feature property that holds a function result
I want to add a property to a feature, that contains the result of a function.
In my case it should contain the min. distance to another feature.
Can this functionality set up via geospatial administrator (property watcher?)
or do I have to code a separate function, that puts the return values into the property.
Regards, Stefan.
