Importing GIS data via CLI
I am using the command line interface to import shape files to Bentley Map. From reading this http://docs.bentley.com/en/Map/MicroStationMaphelp71.html#nowhere it appears to me that there is no way to set the angle of cells in the CLI as in the gui: http://docs.bentley.com/en/Map/MicroStationMaphelp58.html#nowhere
Is it in there and not documented for the CLI? I have the same question for the text angle.
Regards Jakob
