I've got a problem accessing by VBA user attributes stored in Linkages in a dgn file.
Could somebody please have a look on below code and advice. The TransferBlock procedure for sure works fine because I tried it in different macro which shows the id of selected element (not feature).
The macro itself is a modified one from Bentley Map V8i Development and Product Customization Guide.
I attach the .mvba file and sample dgn.
clsLoadProperties:
Implements ILocateOpEventsPrivate Sub ILocateOpEvents_OnCleanup()End SubPrivate Const lIDGL As Long = 889 ' ID of mine attributePrivate Sub ILocateOpEvents_OnFinished(ByVal locateOP As xft.ILocateOp) Dim fe As FeatureEnumerator Dim oElement As element Dim IDglReturn As Long Dim tDBlock() As DataBlock Set fe = locateOP.GetLocatedFeatures Dim oFeature As feature Do While fe.MoveNext Set oFeature = fe.Current tDBlock = oFeature.Geometry.GetUserAttributeData(lIDGL) TransferBlock tDBlock(0), 0, IDglReturn, False With oFeature .SetProperty "id_gl", IDglReturn .ApplyAttributeChanges .Write (False) End With Loop End Sub Private Sub ILocateOpEvents_OnRejected(ByVal RejectedReasonType As xft.LocateOpRejectedReasonType, RejectedReason As String)End SubPrivate Sub ILocateOpEvents_OnTerminate()End SubPrivate Sub ILocateOpEvents_OnValidate(ByVal RootFeature As xft.IFeature, ByVal element As element, Point As Point3d, ByVal View As View, Accepted As Boolean, RejectReason As String)End SubPrivate Sub TransferBlock(dBlk As DataBlock, lOffset As Long, value As Long, _ copyToDataBlock As Boolean) With dBlk .Offset = lOffset .CopyLong value, copyToDataBlock End WithEnd Sub
The mvba attached
After looking at the provided budynki_shape2.dgn file, it is at first not apparent which elements contain your user attribute data. Using pure MicroStation scanning and elements (e.g. no XFT constructs) it seemed that .GetUserAttributeData(lIDGL) always returned a zero sized array. Can you please provide the .mvba that you previously referred to (e.g. tried it in different macro which shows the id of selected element) for review.
Also please be aware that your Budynki feature class is a collection so while the business properties are on the root feature, the geometries will be contained in sub-features so you will need to check the .SubFeatureCount property of the root feature, then call the .GetSubFeature(index) method to get the sub-feature instance.
Jeff Bielefeld [Bentley]
Thanks Jeff,
Please find the macro attached. It works on selected elements.
BTW, I use Bentley PowerMap v8i and if I check element information I can see linkages and the one I'm interested in is Type 0x379.
I'm going to try calling the subfeature method.
I have managed to make in run. I just added to the code those lines:
Set Subfeature = oFeature.GetSubFeature(0)
Set oElement = Subfeature.Geometry
Thanks for the suggestion.
...okay very good, thank you for that update. I would also recommend that before calling the .GetSubFeature(0) method, your code performs a check to ensure that the .SubFeatureCount property has a value greater than 0.
