I have been playing around in the geoexample trying to recreate leadered annotation as shown in the documentation.
However, I find the telco cable leadered annotation method (and others) result in unusable results.
Is this a settings issue I can modify in the GSA or is there another leadered annotation method I can try?
Thanks in advance,Mike
Hi Mike,
to avoid this issue described, you just need to disable AccuDraw the place annotation as expected.
Sebastien Lefrancois
Sebastien,
That was the fix. Thank you for the help!
Mike
