I try to recompile an MDL Geographics application in V8i Map and some .fdf does not exist any more.
For example mapelem.fdf, mapfeat.fdf and so on.
But some function like mdlMap_firstElementFeature, mdlMapFeature_indexFromName exists in geolib.dlo.
The question is, can I recompile declaring those function like external or the function are not available any more?
Thank's in advance, Ottavio.
Ottavio,
Those MicroStation GeoGraphic functions are not available in the Bentley Map product which uses the XFM feature engine. You will need to make use of the XFM API for application development on the Bentley Map platform. I would also recommend posting future Bentley Map related questions in the Geospatial Desktop Product forum.
Jeff Bielefeld [Bentley]
