Hi folks, i just wonder about an error from Bntley Map..
When i did import to the TAB file into my projects and then labeling..next i want generate permanently label for text element..I use the Annotation command..Used First method Current Design File and New Model selected when i press OK button an error appearing like below..
"The active and destination models have incompatibe coordinate sstem which may cause inconsistent to be created. Would y line to proceed?"
I have tried many times other options from "Select Annotation Destination" but I could not do ANNOTATIONS!!
How can i do this?
King Regards..Thank you..
Just to be sure, you have tried to create the annotation in a new model and in a existing model and in both situations the problem occurs?
Can’t replicate that behavior at my end, this could be specific to that file… Does it happen in any file? If you create annotation in a new design file does it work?
Have you assigned a coordinate system to your model prior to import?
What is the Bentley Map version installed?
Carlos
