SynchItem in GSA says "NotFound"
I have two properties that I like to sync using a Property Watcher. I want to update the TextItem Namn in my Oracle Spatial feature when the ComboBox Punktinnehall in the Place and/or Edit dialog changes with the actual value in the ComboBox. When I select something from the Operation ComboBox Punktinnehall the Feature TextItem Namn gets the value "NotFound", ie it seems the watcher knows what property to update but not what value to set. The xml-project is also attached.
