Hi
Is it possible to get just a little more information about the enhancment of the API's in the upcomming Bentley Map SS3.
For instance will there be an API for PrintPreb. ?
Will there be more functions in the XFT Object
etc.
Erik Wirring
Greetings Erik,
For the Bentley Map V8i (SELECTseries 3) 08.11.09 release, many of the API enhancements will be for use by .NET developers in the interoperability area. A minimum number of XFT changes will be included. No changes are planned for the existing Print Preparation API but might I ask what capabilities are you looking for in this area?
Jeff Bielefeld [Bentley]
Hello Jeff
For the moment I cannot find any API for PrintPreparation in SS2. Maybe I have missed one of the help files.
Could you point where I should look.
Erik
Erik;
Did you look under the Microstation/PrintPrearation/SDK folder ?
Jerry.
Oops! I dont have that folder! I thought PrintPreparation was a Bentley Map thing!
Found instead:
C:\Programmer\Bentley\PrintPreparation\sdk
