Hi all,
I'm new to Bentley Map. I am tying to run this through Microstation v8i and InRoads v8i SS2. After loading InRoads I go to the Activate Map icon and when I click the icon Microstation and InRoads both flash on the screen as if the Map software is loading but I see nothing different. There is no indication that the software has loaded and is available for use. What am I doing wrong?
I only need this software so I can export .dgn data to GIS data.
Mike
You should see a couple of menu changes. Look in the main menu, there should be a "Geospatial" menu item under Tools menu and the File menu, you should see a "Map Manager" and "Open Oracle Spatial" menu items.
Otherwise there should be little interface changes.
If you are looking to export GIS data, then look at the File_>Export->GIS Data Types
HTH
Jerry
Jerry,
Thanks for the quick response. I looked in the menus and I do not see any changes in InRoads or Microstation menus. Usually when you load an application Microstation reports this in the message center. I do not have any indication that Map has loaded or failed to load. Any suggestions?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
The Map commands are added to the same locations throughout MicroStation as standard Map. The import for GIS is under File > Import > GIS Data Types... which is at the very end of the list. If you still do not see the commands please call Bentley Support and tell them it is a question for InRoads Technical Support.
Not quite sure why this is a issue. This looks like something that a technical support person needs to look at. Please file a service ticket and they can help you out.
Thanks for the replies. I will file a service ticket.
