Hi all,
I'm new to Bentley Map. I am tying to run this through Microstation v8i and InRoads v8i SS2. After loading InRoads I go to the Activate Map icon and when I click the icon Microstation and InRoads both flash on the screen as if the Map software is loading but I see nothing different. There is no indication that the software has loaded and is available for use. What am I doing wrong?
I only need this software so I can export .dgn data to GIS data.
Mike
I did find another problem that is most likely causing the issue. As I was installing Microstation and InRoads on another computer this morning I noticed there was a Map folder under the Microstation folder. My computer does not have that folder. I am reinstalling to see if that fixes this issue.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Jerry,
The InRoads SS2 version does contain the CADscript tools. They just don't play nice with Bentley Map.
Rod WingSenior Systems Analyst
Well,
I got it working
I uninstalled InRoads and Microstation. I tried a repair and a reinstall of both programs but it did not work. I am wandering if the fact that I had Micostation SS3 Beta installed on my machine was the issue. That folder had the Map folder. After I uninstalled both programs and V8i SS3 Beta and then reinstalled MS and IR SS2 only everything works fine. I am the only person who had SS3 for evaluation and maybe I stumbled onto some conflict while installing that it blocked Map from running on previously installed SS2.
As I was typing this reply I received a response to the Tech Support analyst who was helping me. She confirmed that this is an issue when SS2 and SS3 are installed on the same machine. She mentioned she had the same issue with her computer.
Thanks for the replies,
