Hi all,
I'm new to Bentley Map. I am tying to run this through Microstation v8i and InRoads v8i SS2. After loading InRoads I go to the Activate Map icon and when I click the icon Microstation and InRoads both flash on the screen as if the Map software is loading but I see nothing different. There is no indication that the software has loaded and is available for use. What am I doing wrong?
I only need this software so I can export .dgn data to GIS data.
Mike
In your configuration do you have the MAP_FINISHING = 1 variable set?
I've found that the Activate Map menu selection will not load Map if that variable is set.
Rod WingSenior Systems Analyst
RodWing,
Thanks for the hint. I will look into that. Apparently this is machine specific. I tried some other computers today and Map loaded fine. I was able to export the information without a problem.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Where would I find the MAP_FINISHING variable? I looked through <workspace <configuration and did not see it listed.
If you don't see it then it hasn't been defined and it is not the problem. The MAP_FINISHING variable is used to load the Map Finishing tools (formerly CADscript).
In the Inroads version, I do not believe it has the same product tier delivered as Bentley Map Enterprise ( which includes cad script).
