is there any chance to copy feature definition or property definiton in Bentley Geospatial Administrator SS2?
I have several features in my project that have the same properties. So I wonder if I can copy definition of these common properties from one feature to another. So I don't have to create these same properties again and again...
I use Bentley Map SS2, my project is small resarche project and I save all properiteis in self-contained XFM DGN file.
ula
Hi Ula,
If you are familiar with GSA and XML file structure, you can try to copy and paste the desire feature definition by using any XML pad program alternatively.
Beh
Hi Beh,
good point! I didn't thought about it in this way ;)
Ofcourse, when I have XML schema I can edit it in a XML pad program!
Thank you for good sugestion! I will try to follow up.
Ula
