I am working with map files in V8 XM and will be switching to Map V8i later this year. All of our current map .dgn files are set with a certain paper map scale (ie. 500,000). In my current configuration when I open the coordinate system dialog box I can see and edit the coordinate system, map origin, and paper scale. When I bring my .dgn file and open it with map V8i and open the coordinate system dialog box there is no longer an option for paper scale. Can someone tell me where the paper scale setting are now located? Thanks
Thanks. Looking forward to the file.
