wms service and printig
please anybody know detail about this powermap SS1 behaviour?
i have wms map attached as raster, it has two layers: general map for large scale (view range) and detail map for detail (small scale view fe. 100x100m). It works good for viewing maps are chnged correctly while zoom in/zoom out .
Now , when i  see a large map (my view range is 10x10km),  i place fence from view and i would like to print it using pdf microstation driver. It looks fine, in the print preview i can see general map raster as i can  in my view. But when i do print funcion, after pdf is created ...  in pdf file i can see detail map,  it means  i can see different map because in print preview was large map.
in the pdf i can see small shapes (tiling), and maybe from this little range a print tool decides to use small map insted of large one .
Is there any setting to print wms raster layer in the same way as int print preview is? Or is this beaviour a bug?
Thanks very much for any hint or idea
Jan
  • I believe the issue is related with the resolution used when printing the WMS not being the same as the resolution of the data visualized on the screen. What you may want to try is in the “Print” dialog under the “Settings” menu, select “Raster Options”. One of the option is: “Quality Factor”. Reducing this number will have impact and might lead you to match printing and display resolutions and therefore the output.
    Carlos
  • Carlos, thanks for quick help. Reducing coeficinet to 25  => 150dpi helps. If you seaid it is related with monitor resolution, is it possible to appear same problem on fe. customer PC with different monitor resolution? Or what kind of resolutions must be same? thanks you very much for explain it. Jan
  • Hi Mathieu,
    thanks for explainig it, it hepls.
    I thing, one another thing is important. It seems like microstation does tiling befre ask WMS for data. In your example: if range on my screen is 200x200px is send request for example for 4 squares and for printing it request for example 12 smaller squares on same area - because there is largest resolution. Now - WMS tells: ok, the sqare is smaller -  i will send you more detail map.
    I can reduce raster quality for printing, and this causes that the request sqare has same size as my previous view reqest - same map is returned.
    Do you agree?
    I'm afraid, there is no tiling/tile size settings in Power map. What do you thing?
    thank you once more
    Jan
  • Ah, if I understand correctly you're saying that the WMS server has multiple different "layers" that automatically turn on or off depending on the scale at which you are fetching data. Yes, some servers will do that. It's unfortunate since you are actually specifying which layers you want in the WMS request.
    I'm afraid you are right, I don't think there are any such settings client side. Lowering the resolution of the raster at print should have the effect you want.
       Martin
  • Hi Jan,
    If you check in the Rasterized checkbox the print engine create print raster tiles representing the data to print and send those raster tiles to the printer. Only if you modify the driver resolution (Driver Printer Configuration dialog->Base Properties->Advanced->Driver Resolution) the number of print raster tiles differ, modifying the raster quality does not affect the number of raster tiles.
    If you leave the Rasterized checkbox uncheck the print engine doesn't create print raster tiles but send the vector and raster data directly to the printer.
    So the Rasterized option doesn't have an impact on the quality of the raster data printed. Only the DPI of the print output medium (i.e. : sheet of paper, .pdf specified by the Driver Printer Configuration dialog->Base Properties->Advanced->Driver Resolution option) or the Raser Quality Factor is influencing the DPI of the raster data printed.
    My advice is that you use solely the Raster Quality Factor available on the Print - Raster Options dialog to specify the correct DPI of the raster without diminishing the quality of the vector data to be printed, if any.
    You don't need a tiling size setting. You just need to compute the DPI of your computer screen and tune the Quality factor in order to match the Raster resolution (dpi) information displayed on the Print - Raster Options dialog with the DPI of your computer screen.
    HTH,
    Mathieu
  • Hi Martin,
    Even for one layer the WMS server might have different representation of the data at different scale.
    For example if you have a layer representing the road network of a county it is quite possible that only the major highway are present at lower resolution (view of the whole county) while smaller less important roads become visible at higher resolution.
    Mathieu
  • thanks to all, finally I solve this "somehow"  - explaining : my print solution is a part of mdl program for automatic printing a set of fences - using two different wms maps and i can compute raster quality factor from papersize and fencesize  ... like Martin said: "Lowering the resolution of the raster at print should have the effect you want." there is no other settings to affect this.  regards Jan
Reply
