BM config set config variables outside workspace?
I have a project defined in GSA and an exported workspace. It seems that some config variables (MS_SYMBRSC) get additional values and I can't figure out at what point they are set. I've tried both =, < and > in the macros section but the system path is always added at the end.
I added -debug to the shortcut (msdebug output attached) but in this file only the definition of MS_SYMBRSC from the workspace cfg-file is found. When Bentley Map is started an additional path is added to the standard location. At what point is this additional path added to MS_SYMBRSC? This could be the case with other variables as well.
I need to point font resources to a single cataloge, otherwise font numbers might be duplicated.
Krister
Parents Reply Children
