Is it possible to define the Where clause in Interoperability at run-time using VBA or mdl? I need to filter data on eq. job_id or user_id. I know that I can save orax files but this only works for setting that does not change over time.
Krister
I can dig up some .NET code that has this in it. Not sure about MDL. Would that suffice ?
Anything is appreciated but in this project it's mainly mdl and vba.
/Krister
Owner consultant at Surell Consulting AB
Great!
Hi Jeff,
your example would be a great help for my project since I need a similar functionality. The only problem is that I can't access the file since it's password protected. I would kindly ask if it's possible that I get it?
Marko, that FTP site he published the file on no-longer exists. Jeff will soon be publishing his content to the updated Bentley Developer Network (BDN) site: https://developer.bentley.com/
Marko,
As my colleague Dan correctly stated, I will be working in the coming months to make available from https://developer.bentley.com/ the Bentley Map developer content previously provided on the "Bentley Geospatial Desktop Platform Extranet" site. If you would direct message me with version number of Bentley Map or OpenCities Map you are using, I can provide you an archive of the requested example.
Jeff Bielefeld [Bentley]
Thank you Jeff! We have already managed to setup plugin that we needed so we are good for now!
Best regards,
Marko
