SHP file to DGN with resymbolisation.
What is the best workflow method (and software required ) to take SHP data and convert to DGN, resymbolising and changing the the level of each feature based on the attribute values for each feature.
A bit like thermatic resymbolosation in Map expcept the level need to be changed too, and output to a new DGN.
The process needs to operate in a ProjectWise environment.
TIA.
Parents Reply Children
