Bentley Map Annotation (Labeling)
I am investigating Bentley Map, but I have come across a problem with Annotation or Labeling.  I have experience using ESRI and MapInfo products.
I would like to open a SHP / TAB file with Bentley Map and Label each element with attributes from the associated database.  I can review these attribute, but how do you label with these attributes??
 Cheers Ian
Parents Reply Children
  • Hi All,
     I am still stuck on this problem.  I have an Oracle database and the latest Bentley Map V8i and still I can't find an option to automatically label the features from the Oracle Spatial database.  Have I missed something?
    I also found that Bentley Map V8i doesn't like the Oracle 10g Client (and you need to install the 11g Client) and also it doesn't like the 64-bit 11g Client.  So for Bentley Map V8i you need to have the 32-bit Oracle 11g Client to use the 'Open Oracle Spatial' feature.
    How do people work around this problem?
     Cheers Ian
