Good dayI've worked with Geographics with texts (centroid) and Boundary. It was a clean line network. The factual data could be transferred quickly to changing boundary. As far as I know Bentley Map is now working more area oriented. I work with Bentley Map (SS2).My problem: The source map has changed a lot. My idea is to transfer the property data to centroids and then attach it back to the newly formed area.It is a feature collection consisting of a polygon and a text.Who can help me?
Jens
Are you wanting to take existing GG features and make them into XFM features with a polygon and annotation ?
Jens,
From your description it sounds as if you want to copy the business property values from some source data to instances of your new polygon collection feature class. Is this correct? If so is the text you refer to the annotation sub-feature text of your polygon? Is this text created from a Property Based Annotation (PBA) expression? Could you additional details on the source data (e.g. is it point features, other format etc...)?
Are you comfortable with programming in VBA or other supported development languages such as C/C++ or C#?
Jeff Bielefeld [Bentley]
First, thanks for your answers.As an example, I send them an excerpt from the schema file.There you see the feature Fl_Nutzung_Collection.I want to transfer the property on a centroid point to this lateron a new area formed.With Visual Basic I am a little familiar. Am grateful for ideas.
Is the centroid point from which you want to copy the business properties a different feature class? Do the centroid and polygon feature classes share the same exact set of business properties or do you expect you will have to map property names from source to target feature classes?
Is your company currently a SELECT subscriber or BDN (Bentley Developer Network) partner?
Jeff,The centroid point to which i want to copy the business properties is a different feature class. Point feature with exact set of business properties the polygon feature.My company currently a SELECT subscriber.
