Bentley Map FME Intergration Query
I am in the process of trying to convert data contained in a google earth KMZ file into a DGN for microstation to begin compiling drawings for my client. I have tried many options (text files being a slow method) but see there is a way to do this using FME integration run through Bentley Map for Microstation.
It appears I may need a specific installer to achieve this end result.
How would I go about converting between the two format types.
Suffering some production losses so this is quite an urgent request
Lloyd Wallace
Ilifa Africa Engineers
  • Bentley Map SS2, and the upcoming SS3, are able to work with FME for import and export. Yo usimply have to install FME and have a valid license of it, on the same machine that you run Bentley Map. Installation order is not important.
    If you are running V8i SS1 you needed to install an add-on over Map for FME support, if memory serves me right.
    Hope this helps,
       Martin
Reply
    Hope this helps,
       Martin
