Import ODBC and CSV data types
Bentley Map's Interoperability features can be used to import data from CSV (comma separated values) or ODBC data sources. Often customers maintain features such as survey monuments, borehole locations, leaks, place names and so on in text files or ODBC databases. The attached materials provide a document and working examples of importing CSV and ODBC data types.
csv.zip
  • Is the interoperability options applicable to my version?.  I have big table (in .xls  format)  of points to plot, and I need an automated way, can u help me?
  • Bentley Map is not MicroStation
    Cesar:
    Is the interoperability options applicable to my version? I am using a Microstation V08.01.02.15 (1990-2003) version (not a Bentley Map)
    KeithRaymond:
    Bentley Map's Interoperability features ...
    You seem to be confused. You are reading a thread in the Bentley Map forum.  Bentley Map is a GIS tool. However, you are using Microstation V08 version, not Bentley Map. MicroStation is a 3D drafting tool, not a GIS tool.
    Clearly, not all features available in Bentley Map are available in other products. Those other products include MicroStation. So, no, Bentley Map interoperability options are not available in MicroStation.
    Since you are not using Bentley Map there is little point in asking questions in this Forum. Instead, post questions about MicroStation V8.01 to the most appropriate Forum.
    Regards, Jon Summers
    LA Solutions
    LA Solutions
