I was wondering if someone can test a quick import/export worfklow for me. I have lots of 3D buildings that come in the form of a KML file. So, each building has its own KML file & DAE file (Building_1.kml, Building_1.dae). What I would like is to take all the buildings and merge them into one kml/dae file.
Can someone try importing the three kml files and then export all three buildings as single kml file? I have attached 3 example files. Thank you very much!
Jesse
Jesse,
I think you will have to use standalone FME Desktop product to merge several collada (*.dae) files into a single collada file.
In FME Desktop there are separate readers for Collada and KML.
If I am correct, the KML is only a pointer to the Collada file and will not make sense merging them.
I have done the merging of dae files using FME Desktop and have posted it here for your review.
~SRG
