Resymbolization using GSA and setting Criteria. (Property Based Symbology)
Anonymous
Anonymous
When we first set up GSA it was with Map XM. We set up GSA to resymbolize polygons according to specific criteria. It worked fine (one of the few things that worked in Map XM by the way).
Now we're using Enterprise Map Select Server 2. Using a copy of the original xml file with a workspace created through the new version of GSA. I have been doing some edits to the GSA xml file to add features and commands we hadn't had previously. All is working marvelously except our polygons aren't filling with the colors specified in the xml. The associated lines ARE accepting the correct colors according to the criteria.
I need some places to look. I can manually change the color but that's obviously a non solution.  The blocks in this picture are supposed to be filled with colors other than grey.
Please help
Parents Reply Children
