Using the symbolization functionality in Map manager (using Enterprise Map SS2) on a point data set the spatial orientation and scale is corrupted.
Original orientation of the data points. (in default model)
map model after symbolization.
Hello Doug,
After investigations on my side, I finally reproduce the issue you have reported. Unfortunately, I do not have any workaround to suggest for now, except that issue does not occur anymore in last release of Bentley Map V8i (SELECTseries 3). So, I suggesting to you to upgrade your actual version of Map. Please contact Sales for more details.
Thank you and Best Regards,
