I have a feeling that I have entered this problem witn old Bentley Map SS2 earlier.
Anyway Bentley Map SS3 does nor handle Danish ÆØÅ correct when importing Mapinfo Tab files.
Features containing one of these letters will be misspelled and thus ends up in a wrong feature-class
The highlited feature ought to be "nyafob_brønde"
Here how it looks after importing. The positiv part of this is that value in Name is correct with an "ø"
attached is a zip file: "Ågerupvej - Som udført tegninger.zip"
Do I need to send a prober Trouble Report or is this sufficient ?
Erik Wirring
GEOspatial SIG -- BentleyUserDk
Erik,
I don't see the referenced "Ågerupvej - Som udført tegninger.zip" attachment. Could you please verify?
Jeff Bielefeld [Bentley]
Sorry Jeff,
I must have forgotten to attach the zip fiel.
Using the provided test case, I have confirmed the described behavior and have filed/scheduled an issue to be resolved as part of the upcoming Bentley Map V8i (SELECTseries 3) 08.11.09 maintenance release, currently targetted for Q3 2012 timeframe. I apologize for any inconvenience this may have caused.
