Is there anyway to export dgn text elements to TAB text
Hi all
Is there anyway to export dgn text elements to Mapinfo TAB format text without changing the dgn text element to xfm features???
"Quick and dirty export"
//Tom
  • Hi Tom
    As far I know, only XFM features can be exported from Map Interoperability.
    This is a test
  • Hi
    All other dgn elements (almost) except text elements are aviable to export throght Map Interoperability and there is an workaround to manage the whole thing but that is to go outside dgn, that is to save the dgn as an dwg file and then import the dwg throught universal translator (built in) into MapInfo and the text elements are imported as text in MI.
    Is it worth to create a CR for this issue ???. What do you think about it.
    It would be great to be able to export the RAW dgn file and get all the information from it to TAB.
    //Tom
  • Jeff, Jeff thank you again!!!
    Can´t you come to sweden to answer some (minor and difficult) questions, hold an sessions for couple of days to sort out a LOT of our problems for the future use of BM. It would be so much easyer to implement BM if these kind of answers would be aviable to manage as you can.
    There seems to be answers to almoust every problem that occure in BM, but the answers are coming from the other side of yhe ocean and the time differences and prioritys for support is dependent how you folks work, so please consider to force some of your experties to be aviable in Europe also!!!
    Or Jeff, sweden is an nice pleace to live in if you wan´t :)
    Best regards
    Tom
    BTW. I think that Bentley corp. mind is to enginneering, because of these kind of comments "However there are a number of factors we must consider ". I know is good to consider one thing to another , but in engineering (modern) in my oppinion it would be better to get some kind of "neutral" solution first and then improve it rather than skip the idea totaly because the engineer break quote " However there are a number of factors we must consider ". Take more chances in product development and sort thr bad ideas from the good by users testing and use resaults. I think that a lot of cr:s are just for this reason, Bentley, get more attitude and spine to bring forward "un considered solutions", do as me "think outside the box".
    Tom
  • Tom,
    I had a similar question from a user somewhile ago. I made VBA based on Jeff's example from his previous replay.
    With the attached VBA a property is loaded from a textstring. The text (or text node) will become an XFM feature and the property is loaded with the text string. If the property already exists it is updated.
    The dialog offers:
    •    A list with available features that is deferred from the XFM schema and optional from the available levels.
    •    A list with existing properties from the selected feature. If needed, a new property name can be entered.
    •    Optionally the rotation of the text string can be stored in a property.
    •    With the Process button the whole DGN file is scanned for the selected input feature.
    Note: An XFM schema is not needed.
    e.g. in the case a session feature (a level name) is selected, and the property names are entered  manually in the dialog.
    As a result the text strings can be exported to SHP and MapInfo.
    Kees
    text2xfm v1.5.zip
  • Hi Kees
    Tested your vba today, excellent.
    Tom
  • Hi Jeff
    I have a little problem getting your macro text2xfm2 working. I have loaded the vba project manager an found the .mvba-file.
    When I open the macro window it's empty, so I can't run the macro. I'm pretty new to MicroStation, so I don't hope that I am doing something wrong.
    Hope you can help.
    Rune
  • You have to start the MVBA-Macro from the MVBA-Project-Manager not the MS BASIC Macros!
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
Reply Children
