Wise forum folks,
One more question for you. XFM Schema appears to have difficulty with interpreting "complex" criteria (e.g., criteria that reference more than one attribute), such as:
([attribute1]>0) && ([attribute2]<100)
Or even better:
COMPARE("[attributea]","True","") && ([attributeb]>0)
I couldn't find guidance in the Help files addressing situations like this. Has anyone else tried something similar?
Thanks.
Janice
Hi. This should work. You can refer to an example in the geo_example schema that is delivered with Bentley Map. Look at the road_name criteria.
Martin
Martin - thanks, I'll take a look at the example schema. Might come back with some more questions after that.
Ok, I took a look at the road_name criteria. It looks almost identical to the first example I gave, inasmuch as it concatenates two conditions, each evaluating a different attribute, that share the same basic logic (i.e., both are COMPARE criteria):
COMPARE("[Road:Name]", "MAIN","") && COMPARE ("[Road:Type]","2-Lane","")
So Example #1 works - check. But what about Example #2 that I gave above? The main difference here is that both conditions have different sort of logic. The reason I ask is because the last time I tried to implement this scenario, it didn't work.
Also, for what it's worth, what's the difference between the following criteria expressions? Both evaluate a feature's property value as a string against the string value "compareValue". I get that the second uses the C string compare function "strcmp", but what's really the difference here? Just curious.
COMPARE("[feature_instance_alias:property_name]", "compareValue", "")
0==strcmp("[feature_instance_alias:property_name]","compareValue")
COMPARE function allows passing a delimeter string in the last parameter to compare a value against a delimited list of possible values.
For example...
From "Performance Notes" paragraph in the XFM Overview section of the Bentley Map Customization Guide (search for "Performance Notes"):
If you need to compare a single property to numerous values then use the COMPARE function with a delimited list of values instead of separate COMPARE functions.
Instead of: COMPARE("[SIZE]","220","") || COMPARE("[SIZE]","240","") || COMPARE("[SIZE]","640","")
Consider using: COMPARE("[SIZE]","220|240|640","|")
Chris
