I have never seen a command to strip XFM data from select features but wanted to ask to confirm it doesn't exist (up to MAP SS2).
Also, in reviewing the COM / VBA extensions for XFM I also have not been able to find a simple way to safely remove XFM linkages. Many ways to create / attach linkage but don't see any to remove.
Here are some of the situations:It is a very common need for us to be able to copy an existing native feature, queried from Oracle Spatial, reshape it and use it as the basis for a new feature instance.Expected workflow would be to copy existing feature, remove the XFM data from this copy (without altering or damaging the original feature), modify this new feature/graphic, and then promote this item to a new native feature.
It is also very common that we need to create construction lines / offsets / etc. from existing native features to use as a drafting aid. However this is not practical because copied elements retain the XFM linkage and things end badly as expected.
I do find it a little unexpected, even a little odd, that copied elements retain their original linkage which guarantees problems in workflows we are aware of. Actually, is there any normal workflow where copying an existing native feature does not result in a broken file? Anyhow, I digress.
Our expected workaround was to write some custom tools that could perform the copy / offsets / etc. and strip the linkage in the process.However, the whole XFM paradigm has some rather un-obvious complexity and it seems like it would be very easy to break existing linkages if not handled properly.
Now that I have rambled on, I guess the core question is:What is the "proper" and "safe" way to strip XFM linkages from copied elements without damaging the existing features?Preferably via COM (VBA / .NET)
Thanks,-G-
Gerald,
In Bentley Map today, there does not exist any user level type command that strips intelligence and linkages from an XFM native feature instance. There are however some ways to achieve this result using the Bentley Map API using C or C++ native code. I could assist you with development of such a command but before we venture down that path I'm quite interested in the workflow issues described in your post.
When an XFM root feature instance is copied, Bentley Map is designed to create a copy but ensure that the (new) feature instance can stand on it's own. In the described Oracle Spatial workflow you should be able to query an existing XFM feature instance from Oracle Spatial, copy it, modify the geometry of the new feature instance and post it back to Oracle.
Are you possibly copying sub-feature geometries? If so then the behavior is controlled based upon the "Propagation Rules" defined as part of your XFM schema. These "Propagation Rules" allow you to define (as part of the feature class definition) the desired behavior during MicroStation manipulatiion commands such as copy, move and delete.
The following video illustrates a single XFM feature instance of a cable with multiple annotation sub-features. The feature class definition has defined the "Propagation Rules" in such a way that whenever the root linear cable feature is moved, all annotation sub-features (children) move with it. The annotation sub-features themselves each have rules that define their behavior duing MicroStation manipulation commands. For example, the blue sub-feature text elements (Cable - 2, Cable 10) are allowed to be moved independent of other parts of the feature instance, however the orange sub-feature text elements (Cable - 2 - A, Cable - 2 - B) always move with their immediate parent. Each orange child sub-feature text element is allowed to be moved independent of it's parent.
Please note that double clicking on the video once it is playing should enable full screen video mode.
Please refer to the "XFM Feature Propagation Rules" section of the Bentley Map help for additional details.
Could you provide me with a sample design file in which the XFM feature instance does not exhibit the behavior as you would expect? A copy of your XFM schema would also be valuable for diagnosis. Depending on the size of your design file and schema, you may want to post to our FTP site using these instructions then notifying me of the upload.
Jeff Bielefeld [Bentley]
Jeff,
That got me thinking and I just double checked what the actual error is.Looks like the Feature ID's are acting properly as you describe.Turns out that the problem is with database ID's.We have a sequence in Oracle XFM_ID_SEQ that is set up in the "Id Generators" in the GSA.Everything works fine normally.
However, when we copy an element then on post we get a unique key violation on the XFM_ID.So apparently MAP is not attempting to pull a new ID from the sequence.Is this expected?
None of the features in question at the moment are sub-features, but you bring up a good point.I do need to review the GSA to see what behavior we would get in that case, I would not be at all surprised if this is incorrect / incomplete as we have not gotten to that point in the project yet.
Currently for all the root features, with no sub features, all of the propogation rules are set to "Never".
I will gladly send you the GSA. I do not have it available at the moment, but will later tonight.
Thanks!-G-
First thank you clarifying what was actually occurring. I wanted to ensure that you were aware of the purpose of "Propagation Rules" so that you could apply them as desired in your workflows.
Next, the copied feature instance should be seen as a new thus causing the Oracle Spatial post process to insert one or more new rows (depending on the feature class definition) and obtain new required primary key (PK) values where necessary, from your sequence. If this is not occurring then I would suggest that you file a Bentley Service Ticket so that our analysts can fully diagnose the problem
From what I can tell thus far in this thread, what you are attempting to do is a fully supported Bentley Map workflow.
Thank you. Creating new features works perfectly. Promoting features works perfectly. When copying, they are indeed flagged, recognized as "new" features and assigned new UUID's. But on post they are not getting new PK values from the sequence. So it looks like I will need to file a service ticket.
Getting that working should solve one of the challenges.Now, back to the other part of the conversation.How about the ability to strip the linkages off of copied elements for the sake of using copies / offsets as construction lines and such?These new elements would be completely disposable and do not want them to be posted back and do not want to damage the existing feature.
My C skills are very rusty. I'm from the old K&R C days before they started decorating it with "+" and stuff ;-)But that doesn't stop me from hacking away. Although I am quite proficient in other dev platforms.
So do you have some guidance to point me in the right direction on how to accomplish this the proper and safe way?It would be much appreciated!
It good to hear that your feature creation, promote and copy processes are generating the UUIDs as expected. Once you file a Service Ticket for the failed post process, I'm sure our support analysts will be able to assist and determining the cause of the failed PK generation.
Regarding the stripping of the XFM intelligence from copied elements, could you describe how you would want a command like that to work? For example, do you first want to copy the feature instance, then remove the intelligence in a separate step? Would you prefer to have a special copy command that allows you to select any part of an XFM feature instance and copy it (as you do with MicroStation) to a new location w/o the intelligence?
Depending on your response I may be able to craft a small application that achieves the desired result.
