Im working with street light infrastructure.
Recently ive got the Bentley Power Map v8i tool to work with.
I see thaat there is a posibility to add a db to it.
But here is the catch, for the moment I was working with raster map images only.
Wrigh now Im redrawing the rasters to a vector map so all information is storen in DGN format.
As my intuition tells me I would need a position of lamp (x,y, maby z also), the hight of it, type of pole, street , and the number of lamp.
I can think of this in a excell sheet but Ive never done a database before :(
Can you help me with this one?
Can you pleas help me to create a simple db that I could hook up to the bentley?
Best regards Maciej.
I have created a sample db :
http://communities.bentley.com/members/Jerry-Walter-_2D00_-Bentley/files/sample.mdb.aspx
As for the anology with Excel, look at the db this way :
The sheet tab in Excel is the same as the table in the db.
The row in Excel sio the same as a record in the db table.
The column in Excel is the same as a field (column) in the db table.
HTH
Jerry
Hi Maciej,
if you work with Power Map V8i, there is a question where is the best to store the non-graphical information (attributes). As you wrote your can attach an external database to elements but you can also create XFM project and to store the information directly in DGN file. Both ways have own pros and cons, so you should to think how the data will be used.
In my opinion XFM project is a more complex way, but better in longer perspective as you don't have to maintain "sychronization" between DGN and DB. But the question is also how many object you work with etc.
WIth regards,
Jan
whell te inpt number of light pionts is around 3800 and also there are some control cabineta as well as a stering and supply lines that have to be characterised. So I think in total there can be up to 10000 elements.
Can you tell me some more thing about XFM?? I never heard about it before.
MaciejG said:Can you tell me some more thing about XFM?
Hmm ... not easy request, because XFM is complex technical topic, there are information available at Bentley site already. But let's do simple short (which means not precise in some aspects) introduction :-)
There are two important "questions" related to GIS on Bentley platform:
What is XFM project?It's technology, which is the base of Bentley Map and it provides answer to both mentioned questions:
I can imagine a project with several DGNs (it's not a good idea to store nearly 4000 features in one DGN), where the property (attributes) you mentioned willbe stored in DGN file also. But it require at least short analysis and more information to make a correct decision.
I hope it will help you,
There are excellent courses offered by the Bentley Institute for this very subject. Please lookup the "Bentley Map Administrator" course at
learn.bentley.com/.../Public
