Databrowser do not show properties all though they are defined in the FeatureClass definition cache
I have got a problem that at least did not exist in BentleyMap SS2. I have veryfied that it exist in Bentley Map SS3 built 95 and sadly enough also in the new service release with built no 107.
In short:
I have a small Mvba app that defines a new featureclass OisPunkt with a number of properties. Then I create a number of these features and I can check that they are created with the properties. BUT when I start the databrowser it will not accept the feature Class defintion and show only the feature instance without properties.
Documentation:
FeatureClasse definition
Mvba code creating and verifying the feature class definitions:
CreateFeatureClass and AddPropertyToFeatureClasse are both functions in a MDL DLL
Public Sub StartOisClient(ByVal feltliste As String)
Set OISclient = CreateObject("OISlib.OISclient")
If OISclient.SetLogon(OISUSER, OISPWD) = False Then
'ved at spørge på paramtren sættes den
End If
If modX34featdef.TjekFeatDef("OisPunkt") = False Then
CreateFeatureClass StrPtr("OisPunkt"), XFMFEATUREGISTYPE_PointLine
End If
If modX34featdef.TjekFeatAttribDef("OisPunkt", "MATR_NR") = False Then
AddPropertyToFeatureClass StrPtr("OisPunkt"), StrPtr("MATR_NR"), XFM_DATATYPE_STRING, 10
AddPropertyToFeatureClass StrPtr("OisPunkt"), StrPtr("EJERLAV"), XFM_DATATYPE_STRING, 80
End If
Dim Felt As Variant
Dim strFelt As String
For Each Felt In Split(felt_liste, ",")
strFelt = Felt
If modX34featdef.TjekFeatAttribDef("OisPunkt", strFelt) = False Then
AddPropertyToFeatureClass StrPtr("OisPunkt"), StrPtr(strFelt), XFM_DATATYPE_STRING, 80
End If
Next
modX34featdef.DumpFeatureDefinitionProperties "OisPunkt"
End Sub
Here comes the code for DumpFeatureDefinitionProperties:
Public Sub DumpFeatureDefinitionProperties(FeatureName As String)
Debug.Print "--------"
Dim message As String
Dim oFeatureDef As FeatureDef
On Error GoTo ***
Set oFeatureDef = xft.FeatureMgr.GetFeatureDefinition(FeatureName)
Dim strGeomType As String
Select Case oFeatureDef.GeometryType
Case 0: strGeomType = "UNKNOWN"
Case 1: strGeomType = "LINE STRING or CURVE"
Case 2: strGeomType = "POLYGON"
Case 3: strGeomType = "POINT"
Case 4: strGeomType = "TEXT"
End Select
message = "FeatureClass: " & oFeatureDef.Name & ", " & strGeomType
dmsgPrint StrPtr(message)
Dim numProperties As Long
numProperties = oFeatureDef.PropertyCount
Dim propertyIndex As Long
For propertyIndex = 0 To (numProperties - 1)
Dim oPropertyDef As PropertyDef
Set oPropertyDef = oFeatureDef.GetPropertyDefinition(propertyIndex)
message = " " & oPropertyDef.Name & ", " & oPropertyDef.TypeName
'Debug.Print oPropertyDef.Name, oPropertyDef.TypeName
Next
End Sub
Here comes a Analyze Feature of one of the newly created features:
And last the Databrowser:
What has happen since version SS2 since the Databrowser (and the Edit feature function as well) no longer uses the feature Class definition cache
If I close Bentley map and open with the same designfile the Dynamic Feature Scoring findes the properties (offcause)
Erik Wirring
LE34
  • I do not see xfmcore.lib in that output.  You will need to also link with this library.
    Chris
    This is a test
  • Hi Erik,
    Regarding the DFS created feature definition, you might consider setting up a design application to load after Map/XFM(Map MS_DGNAPPS loads XFM) so you can set the DFS generated feature definition to stay in the session.   xfmFeatureDef_create will tell you if the definition currently exists in the session.
    Chris
    This is a test
  • Thanks!
    That helped -I had not noticed that you wrote that it was in the xfmcore.lib, but now you point it out. I can see my error :-)
    Now my On-The-Fly featuredefinitions stays put if all instance of the feature is deleted.
  • Hi Chris
    I did some more testing and the result is rather surprising, and it indicates that your suggestion propably  will not work .-(
    I took my test file, removed all instance of OisPunkt but left the layser "Oispunkt" empty. Then closed the BMap session, and restarted BMap with my test file.
    just after startop I used the "Mdl command dumpfeaturedefbyname OisPunkt". Here I could see that DFS had not created any featuredefinition on the existens of the layer "OisPunkt". Then I ran by application which create the feature definition and a number of instances of the feature OisPunkt. Tested that the featuredefinition was okay. and last loaded DataBrowser which refused to show the properties.
    Next test I just placed a simple line on the layer "OisPunkt" so it was not completly empty. Closed and reopened BMap.
    First test with  "Mdl command dumpfeaturedefbyname OisPunkt" shows that DFS now has created a featuredefinition:
    command dumpfeaturedefbyname: FeatureDef (0x16247a8) Name [OisPunkt] Path [] Key=266 RefCnt=4
    command dumpfeaturedefbyname: Description [(null)] CategoryName [] GISTypeName [linestring/curve]
    command dumpfeaturedefbyname: IsCollection=FALSE
    command dumpfeaturedefbyname: NumSubFeatures=0
    command dumpfeaturedefbyname: NumProperties=1 NumDgnProperties=0
    command dumpfeaturedefbyname: Owner: ApplicationId=22564, ApplicationType=14
    command dumpfeaturedefbyname: PropertyDef (0x2092ef38) Name[Geometry
    _Length] DisplayName[Geometry_Length] FullName[Geometry_Length] TypeName[DOUBLE]
    TypeId=4 MaxSize=0 External=Y ReadOnly=Y RefCnt=4
    command dumpfeaturedefbyname: QueryNodeList size=0
    command dumpfeaturedefbyname: InsertNodeList size=0
    command dumpfeaturedefbyname: CopyNodeList size=0
    command dumpfeaturedefbyname: UpdateNodeList size=0
    command dumpfeaturedefbyname: DeleteNodeList size=0
    command dumpfeaturedefbyname: DBLinkNodeList size=0
    command dumpfeaturedefbyname: QueryCList size=0
    command dumpfeaturedefbyname: InsertCList size=0
    command dumpfeaturedefbyname: CopyCList size=0
    command dumpfeaturedefbyname: UpdateCList size=0
    command dumpfeaturedefbyname: DeleteCList size=0
    command dumpfeaturedefbyname: DBLinkCList size=0
    Then I started my application which now updates the featuredefinition instead of creating a new featuredefinition along with creating the
    instances of the feature "OisPunkt". Now the featuredefition looks like this (which is exactly the same as in the first test!):
    command dumpfeaturedefbyname: FeatureDef (0x16247a8) Name [OisPunkt] Path [] Key=266 RefCnt=10
    command dumpfeaturedefbyname: NumProperties=7 NumDgnProperties=6
    command dumpfeaturedefbyname: PropertyDef (0x2092ef38) Name[Geometry_Length] DisplayName[Geometry_Length] FullName[Geometry_Length] TypeName[DOUBLE]
    command dumpfeaturedefbyname: PropertyDef (0x198b0e78) Name[MATR_NR]
    DisplayName[MATR_NR] FullName[MATR_NR] TypeName[STRING] TypeId=1 MaxSize=10 External=N ReadOnly=N RefCnt=2
    command dumpfeaturedefbyname: PropertyDef (0x20bb9a90) Name[EJERLAV]
    DisplayName[EJERLAV] FullName[EJERLAV] TypeName[STRING] TypeId=1 MaxSize=80 External=N ReadOnly=N RefCnt=2
    command dumpfeaturedefbyname: PropertyDef (0x20bb9b98) Name[EJER_NAVN] DisplayName[EJER_NAVN] FullName[EJER_NAVN] TypeName[STRING] TypeId=1 MaxSize=
    command dumpfeaturedefbyname: PropertyDef (0x20bb9ca0) Name[EJER_ADR
    ] DisplayName[EJER_ADR] FullName[EJER_ADR] TypeName[STRING] TypeId=1 MaxSize=80
    command dumpfeaturedefbyname: PropertyDef (0x20bb9da8) Name[EJER_UDV_ADR] DisplayName[EJER_UDV_ADR] FullName[EJER_UDV_ADR] TypeName[STRING] TypeId=1
    command dumpfeaturedefbyname: PropertyDef (0x20bb9eb0) Name[EJER_POSTADR] DisplayName[EJER_POSTADR] FullName[EJER_POSTADR] TypeName[STRING] TypeId=1
    And NOW dataBrowser shows all the properties as it should.!
    So is it possible to conclude any thing from this ?
    Erik Wirring
  • Hi Erik,
    I am not able to reproduce results like you mention here:
    "I took my test file, removed all instance of OisPunkt but left the layser "Oispunkt" empty. Then closed the BMap session, and restarted BMap with my test file.just after startop I used the "Mdl command dumpfeaturedefbyname OisPunkt". Here I could see that DFS had not created any featuredefinition on the existens of the layer "OisPunkt". Then I ran by application which create the feature definition and a number of instances of the feature OisPunkt. Tested that the featuredefinition was okay. and last loaded DataBrowser which refused to show the properties."
    I am using Map Enterprise 8.11.9.107 in the msgeo user using the gasmain mdl example.  My observations match until your last sentence above.  In my case, I do see my feature properties as expected.  This is strange.  I cannot figure out what is different between my scenario and yours.
    What Map product and version are you using?  Can you send your dgn with a few of your instances so that I can try your scenario starting from the step to delete the instances in the file?  Can you send the code snippet that creates the feature definition?
    Chris
    This is a test
