Hi,I have another problem with a parcel with a hole: If I delete an isolated edge, the parcel loses it's hole and it's representation changes from a grouped hole to a Polygon Selection.This happens in a cadastre wizard created project, all options answered by default.Here is the description, what I'm doing in the video. If it is too small use strg + scroll the mouse:- I'm using the latest version of Microstation and Bentley Map actually available from Bentley download.- I create a parcel, the area property shows 9978 sq. m.- I create a hole in it.- I split the hole, the area of outer parcel now is 4062 sq. m.- Till yet this test case is fine. We have a grouped hole with a solid and a hole in the element information.- Now, when we delete a part of the splitting boundary, strange things happen:- When you delete the splitting edge of the hole, the surrounding parcel is deleted by the synchronizer.- I undo this error.- When you delete one isolated edge of the splitting boundary, the representation of the area with the hole changes completely from a grouped hole to a Polygon Selection. Look at the area of outer parcel: It has changed from 4062 sq. m. to 9978 sq. m!- In the high lite, now the whole area is shown. The area has lost it's hole; 9978 sq. m. is the complete area of the test case from the beginning.Regards,Tom
