I want to do something like this on these screenshots below:
I've added one criteria : COMPARE("[road_Collection/what_to_do]", "upgrade", "") but it does not work. Can someone help me solving this issue?
Gabriel,
Please try adding brackets around the feature class name and operations property as follows:
COMPARE("[road_Collection]/[what_to_do]", "upgrade", "")
Jeff Bielefeld [Bentley]
Actually upon further review your syntax is correct. I'm attempting to mock up your schema to determine what is required.
Attached is a mock up of your schema which implements the following behavior:
For the "what_to_do" ComboBox property, you will need to set the "Store Last Value", "Save Changes Key" and "Command Type" settings as shown in the following:
Thank you Jeff - my problem is solved.
