Cell with tags as point cell feature?
I have a cell with attached tags. If I place the cell using MicroStation tool, the cell is placed including tags and they can be edited later. But if the same cell is defined in XFM project as point-cell feature, during the placement the tags seem to be removed (the cell is reported as without tags) and no tag set definition is copied into the design file, but later I ocasionally experienced strange behaviour including Bentley Map V8i (SELECTseries 2) crash when I work with this cell later.
Is it known bug / feature / limitation?
Is there any workaround or other solution (including own code) to use cells with tags in XFM project?
Explanation why I have to use tags: Part of design file content is exported to DWG format and cells with tags are converted to block with attributes, which are required to be used.
With regards,
  Jan
Parents Reply Children
