Property Value for feature set in operation property combobox
Hi all,
I want to set property value for feature by selecting correct value from combobox which is define in operation properties.
This is how I made connection between property value for feature and combobox
Then in Bentley Map I have this:
When I choose material on the map appears text "Material" and it is correct but value is wrong (it should be "Material" also)  :
When I insert next text to the map for example "Decritpion" it also appears ok on the map but value is wrong, this time is " Material" so the value which should appear one step earlier :
And so on.
What shall I do to get what I need? I attached my xml file. Any suggestion would be helpful.
Parents Reply Children
