http://translate.google.it/
Microstation V8ì ( select series 3 ) - Version 08.11.09.357
Bentley Map V8ì ( select serie 3 ) - Version 08.11.09.107
I have a dgn that is connected to the geographics coord system EPGs 3004 Monte Mario / Italy 2
when I snap the coordinates of point I would like to have geographic lat and long wgs84 (DD ° MM'SS ") or by using coordinates Label
. I read wiki http://communities.bentley.com/products/microstation/microstation_v8i/w/microstation_v8i__wiki/5869.aspx
but does not work for me or something wrong
you can do? and how?
thanks
Create a new model or a new DGN-File,
use EPSG: 4326 WGS84 for thist new model or the model in your new dgn-file as the GCS
open that new model or dgn-file
attach your geocoord.dgn(deault model) as a reprojected Reference
See:
Maybe you have to adjust the working units and/or the resolution to get accurate values and the unit degree (Degrees instead of projected plan x,y coordinates)
use the label coordinate or use text fields : you will get Longitude and the Latidude values of WGS84!
Frank
I created a new dgn with gcs WGS84 "modello_wgs84.dgn"
I connected as the reference dgn with gcs 3004 EPSG "geocoord.dgn"
I changed the units of measure in degrees and seconds
but I do not read the right values
and when I connect the reference is not displayed (must be 3D?)
sending the dgn and setting
kindly can send me the two files attached back with the right settings?
