Is there a way to create a custom coordinate system from an Arc PRJ file? A major city in this area uses their own coordinate system for their GIS and surveying. I wanted to bring some NED data into InRoads, but since the project is not in state plane coordinates, I am stuck.
I opened the PRJ file and while is it ASCII, but there is no explanation of exactly what is what.
And it is all on a single line, so the grouping of the data, which nests multiple times is not easy to follow.
Here is the data 0 I added a space after every comma so it would wrap:
PROJCS["815586_RSO_feet_rotation", GEOGCS["GCS_North_American_1983", DATUM["D_North_American_1983", SPHEROID["GRS_1980", 6378137.0, 298.257222101]], PRIMEM["Greenwich", 0.0], UNIT["Degree", 0.0174532925199433]], PROJECTION["Rectified_Skew_Orthomorphic_Center"], PARAMETER["False_Easting", 349.37],PARAMETER["False_Northing", 2588.1], PARAMETER["Scale_Factor", 1.0], PARAMETER["Azimuth", 0.0], PARAMETER["Longitude_Of_Center", -76.614429], PARAMETER["Latitude_Of_Center", 39.304635], PARAMETER["XY_Plane_Rotation",0.001], UNIT["Foot_US", 0.3048006096012192]]
In addition to the Help file, the steps are documented (with pictures) in this file: http://communities.bentley.com/products/geospatial/desktop/m/geospatial_desktop_gallery/218386.aspx
I copied the seed dty file to a new folder on my network standards area and added the MS_GEOCOORDINATE_USERLIBRARIES to point to the path and filename.
When I open Map, there is no new entry in the GCS dialog box for me to use.
I noticed another variable - MS_GEOCOORDINATE_EDITUSERLIBS which is set to 1 but I cannot locate any info on this variable.
What am I missing? Found a solution - keep reading...
So here is where I decided to open one of the example geospatial files and voila, it showed me the new custom DTY item and I was then able to follow the process. I then opened a few files and the provided seed file and attached the coordinate system. When I export to Google Earth, it lined up like a champ. I aslo got some mister sid files to align, which was my goal from the outset.
CADDcop, in the same boat but my interpretation of the prj t othe dty must be off.
Could you attach your dty for comparison?
Thx,
Mike
Here is the one I created based upon the settings in the previously posted prj file contents.
