Is it possible to use FME extension in Bentley MAP SS3 ?
After installing Bentley MAP standalone File -> Export -> FME is inactive
yes, if FME was installed before Bentley Map.
Hi. I think it doesn't matter if FME is installed before or after. You need a supported FME version installed and licensed. When Bentley Map started this is checked and the menu will be grayed if the requirements are not met. The installation order was important when we first released this functionality but since the last version or two the behavior has changed.
Martin
