Hi
I have been looking through all the online documentations I could find, but I cant find a solution for scaling a cell acording to a property value. Some dimension values comes in a limited numbers of fixed values .f.i. lids to manholes those I can handle this way:
But if the dimension is the diameter of a tree canopy, this approach is not very productive :-)
Really It would make more sense if one could place the Property Value directly in the Cell XScale value like this:
But are there somewhere a possibility to controle a cell size from a feature property.?
Erik Wirring
Landinspektørfirmaet LE34
Denmark
Erik,
In the forthcoming Bentley Map V8i (SELECTseries 4) release later this year, we've added a new event callback to the Bentley Map API that will allow you to implement custom code in which your application can set symbology settings using whatever values you wish, including the business property values of the feature instance.
Jeff Bielefeld [Bentley]
Jeff,
Sounds great!
I guess it is too late to arrive with a additinal long wishlist at the BLC next month :-)
Regards;
Erik
I guess you already know, but I notice in your screenshot some criteria are set to zero. These critiria will not be evaluate since zero means FALSE for Criteria. This is just to let you know.
Best Regards,
