Something crazy is going on in the GML import in Bentley Map built 107 (We do have the same issues with a lot of WFS service)
When loading a a FOT-topographic gml file, and this is a officiel reference dataset!. The GML importer ab-ends with a error messages saying that xlink has been reference once earlier!
Please look at this line of screen dumps
Here loads the reference dataset. Not specifying any schema, and get a nice list of featureclases:
Then try to import and gets this error message:
'Funny' thing about this is that this dataset has been importet years ago in SS2 and SS3. GML file is attached as a Zip file
We have had a lot of troubles with the Wfs client coming with the same type of errors for different wfs-services. Seems that the problem has it root in the GML importer
It is a rather serious problem for us
Erik Wirring
LE34
Hello Erik,
I hope someone could give us a workaround/explanations about this issue. Until there, I filed an internal report about Importing GML attached file. As reference, the report number is TR 352487.
Best Regards,
