Bentley Map Mobile provides powerful 2D/3D vector and raster viewing along with redlining and mark-up capabilities. It provides fast, efficient access to infrastructure data sets for field personnel of all types, including engineers, inspectors, maintenance crews, construction personnel and others. With Bentley Map Mobile, field workers can be kept up to date with the latest infrastructure data, reducing errors and improving service outcomes.
Bentley Map Mobile is GPS-enabled which simplifies the location of facilities in the field. If a network connection is available, then an interface to Google Maps (on Android and Windows) or Apple Maps (on iOS) will produce driving directions to the selected facility. The view display can be simplified by toggling features off and on, applying scale based visibility. A list of business properties values for all visible features can be easily generated for review. Free text search can be used to quickly locate text annotations or features.
Bentley Map Mobile is currently available in the Google Play Store for use on Android tablets, in the Apple App Store for iPad tablets, and in the Bentley SELECT Software Fulfillment Center for 64-bit Windows 7, 8 and 10 desktops, notebooks and touch enabled tablet devices. Bentley Map Mobile requires the use of Bentley Map Mobile Publisher to publish next generation i-models from Bentley Map Enterprise, Bentley Map, Bentley OpenUtilities Designer, Bentley's communications and other Bentley Map based products.
Bentley Map Mobile requires a Bentley CONNECT login and Bentley CONNECTIONS Passport.
Bentley Map Mobile
Bentley Map Mobile - Quick Start Guide
Bentley Map Mobile - What's New?
Bentley Map Mobile - Frequently Asked Questions
Bentley Map Mobile Publisher - Frequently Asked Questions
