Replacing feature geometry in Bentley MAP SS3
Hello
I have to port a SS2 Map application to SS3
In the application a feature has to get a new geometry, not modify.
The function I use works under SS2 but in SS3 it fails with shapes / group holes
I do this
1 - remove the existing subfeatures
m_Feature.RemoveSubFeature(item);
GeoOperate.FeatureMgr.DeleteFeatureByUuid(App.ActiveDesignFile, item.Uuid, true);
2 - add the new geometry
BXFT.feature subFeature = GeoOperate.FeatureMgr.CreateFeature(item);
subFeature.Name = m_ComponentName;
subFeature.ApplyAttributeChanges();
m_Feature.AddSubFeature(subFeature);
m_Feature.ApplyAttributeChanges();
3 - write the feature (here the exception occurs)
m_feature.write(true)
The feature is locked before.
But what I am doing wrong?
Greeting Olaf
Parents Reply Children
