Bentley Map mobile adding published map files
Tried to copy some published maps to /Bentley/Documents/MapMobile and it doesn't show up in application it only works if renaming the file to "East City". How to force refresh of the map selection screen as restarting the application doesn't help? Also I do not see layers of the published Map it shows only "Raster layer" under Filter.
Parents Reply Children
