Hello all,
I am taking a shot in the dark here, and wondering if anyone has any experience using the FAA deployed Airport Data Model for any AGIS projects? I am to the point of submitting what I am hoping is a complete GIS .DGN and have not had much luck finding anyone who has experience using this data model to completion for a project. The support desk at the FAA seems more well versed in the AutoCAD side of things, and was hoping to chat and discuss experiences with using these standards for Bentley Products. More specifically with how the FAA checks the appropriate feature names/attributes once submitting, and if the cells used by the data model is appropriate for "point" styles, etc. Thanks in advance and hope to hear from someone.
-Jonathan
Rafael A. M.
The Airport Data Model is available for download in the Bentley Fulfillment Center. From the Bentley Support website, select Go To Personal Portal, Software Downloads. Select Map as the Brand & it will be the first item listed: Personal Portal
Unknown said: The Airport Data Model is available for download in the Bentley Fulfillment Center. From the Bentley Support website, select Go To Personal Portal, Software Downloads. Select Map as the Brand & it will be the first item listed: Personal Portal Sounds good. However, My Support account type does not provide the Select drop-down for software download (attached jpg). Further readings suggest I contact my FAA account administrator for them to download it for me. And hope I am understanding this process correctly. I thank you again for your support as I am discovering this site has lots of good leads for my project. Rafael A. M.
This article can help with User Management and Roles: http://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/25124.user-management
