Back in Geographics days I could import shapefiles and it would create the database table with the mslinks. How do you do this with Bentley map? I've been through the import routine but can't figure out how to create the table and populate it and assign the mslink attribute.
In Map you need to :
- Create the database table.
- Define the features in the GSA.
- When importing the shapefile, you then data map the feature to the shapefile and the attributes in the shapefile to the attributes in the feature, then the data will be linked to the database as in the past.
HTH
Jerry
Versions in use: MicroStation 08.11.09.357 Bentley Map 08.11.09.107
