Trying to Create a Shape File from an Inferred Feature Polygon
Using Bentley Map SS3 8.11.09.107
I've been creating shape files of our standard project with XFM features etc. and everything works fine. I then had a need to quickly create a shape file of a few standard Microstation elements which had been placed with the Microstation 'Place Shape' Command. The result is in addition to the standard shape files additional '*_collection' shp,dbf and shx files are created.
The problem is pretty easy to test:
1. Create a new blank DGN file with Bentley Map and use 'Place Shape' to draw a couple of shapes on the default level. NB. The standard MS_GEO Workspace was used to reduce other variations.
2. File > Export > GIS Data Types and use standard process to create a shape file called 'Test.shp'
3. Resultant file output is:
test.shp
test.dbf
test.shx
Default_Collection.shp
Default_Collection.dbf
Default_Collection.shx
4. If you review these output shape files, one will have the first polygon but nothing more. The second shape file will have the remaining shapes.
5. We just tested this on some other versions of Map and it wasn't happening in ....09.51 or .....09.76. It starts to be a problem around 09.91 and is a problem in ..09.107. Was this about the time Bentley went from XFM1 to XFM2 features?
Could someone from Bentley please confirm this problem and suggest a solution?
Thank you.
Parents Reply Children
