Hi
By looking at the geo_example I can see that it is possible to create toolframes and toolsboxes in GeoSpatial Administartor.
However I can not find anything on the help file and even googling for information about this topic doesnot give many clues.
Can anybody help me to some examples and informations. Offcause I can figure out those fields that exist in the menubar section too, but where do the Icons come from.I can choose between three sources.
But if I want to add extern iconfiles that not belongs to MDL (Native C) program how do I do that .
Erik Wirring
LE34
Danmark
Nikolay,
In the delivered geo_example.xml schema, you can see an example of using .ico files in the "dgn_feature_tools" toolbox in the "designer" workspace. The "Road" tool item defines "Road" as the "Root ICO Filename" which references ...\WorkSpace\Projects\Examples\Geospatial\geo_example\designer\icons\RoadLarge.ico, RoadSmall.ico or RoadTiny.ico at runtime depending on tool size user preference.
Jeff Bielefeld [Bentley]
